I have a 2016 VW Jetta S with a 5 speed manual with 138k on the clock. So far since I had my car and I paid for an extended warranty because I do a little over a hundred miles a day.
With that history, these are the issues I had and I believe some of these were updated, or were just a fault in my car alone.
Ok, so I had a check engine light come on within the first 50 miles which was due to some brake issue, which they resolved with a computer update. No issues after that.
My seat broke with like 2000 miles on it, they fixed it no problem.
At around 40k, I had a boost sensor that went bad, put my car into limp mode. Had that fixed and no issues since then.
At 63k, my passenger front strut mount bearing went bad and they replaced that under my extended warranty.
I thought this was an issue, but later found out it was completely normal and I think the dealership had no idea of the feature as well, but when it rains and your wipers are at any speed, when you come up to a red light or stop sign and stop, your wipers will essentially stop and wipe every 20 seconds. That is a feature I believe to prolong the life of your wiper motor and wipers. Give it a try, pretty cool after they replaced my wiper motor and it still did it.
At 89k, I had a lean code that was P2178. This was a nightmare for me and the dealership. My car was in and out of the dealership for a month or two. Now it didn’t cost me a dime, but if I didn’t have my warranty, this would’ve cost a little over 3000 dollars in parts and labor. The P2178 is a lean code. They first changed my spark plugs and coil packs, which resolved the issue for a week or two, then it came back which resulted in them replacing my fuel pump, issue came back within 100 miles, dropped the car off again and told the service advisor to drive the car and take it home and do whatever he had to do to figure out the light. They had it for two weeks and changed the fuel pressure regulator, to no avail the light came back. Finally, they took it back again, it escalated to corporate and had some technician over the phone reading the values, and saw my injectors weren’t running efficiently and replaced them. At that time I also asked them to inspect my valves due to DI problems and to my surprise, they were clean and the tech showed them to me. The injectors were replaced with a “revised” part number and it hasn’t been an issue since then. This was my single most disheartening issue with my car.
At 103k, I paid for the timing belt to be done. I didn’t replace my water pump due to it being on the other side of the motor and at 138k(present time), it hasn’t leaked yet. The water pump alone is the most expensive part of the whole timing job and I left it alone because I can do it myself when it starts leaking.
At 109k, my struts and shocks were going bad, I brought it in and they replaced them under warranty.
And that’s about it. My cousin has a 2018 Jetta SE, and he has a little over 70k, and to my best knowledge, he hasn’t had a problem yet. So I think it’s just me and my high level of wear and tear and also having a brand new car and motor, I was working all the kinks out for everyone else.
So now at 138k, what’s my opinion on my car? I love it and even with those issues, I wouldn’t have bought any other car except maybe went with Passat or Tiguan for the interior space because I’m a family man now with 3 kids and a wife. I’ve done multiple trips to Florida, Lake George, Maryland, Delaware, DC, and other places and my car has consistently got excellent gas mileage upwards of 38 to 44mpg due to the areas and mountains around it. I do get on my car from time to time and it’s been tuned with APR stage 1 since 122k and it’s been fine. I’ve done spark plugs, air filters, oil, tires, brakes, and transmission fluid changes when they were suppose to be done and really can’t complain. The car idles smooth and to this day, I don’t have any creaks or odd noises I can’t find. It’s a really great car. I wish you good luck with your car, the new Jetta’s are really nice and I hope to get a GLI next time around.
