93k. 2012
good to hear, that is good newsTiming belt and water pump done at 84k. Regular oil changes every 5k. Cam follower every 15k. And haldex every 25. Been stage 2+ for 30k miles. No issues.
93k on a ‘12 2+. About to get her third clutch tomorrow (DKM twin disc going in), BFI Stage 3 coming out dead after 28k miles, Sachs before that killed a factory flywheel at 65k miles), timing belt, just had a de-carb and it wasn’t terrible as I did Seafoam treatments every 10k. Other than that I had to clean the push to start, replace headlight level sensor. Guibo is good, but I’m in Vegas and the car has never seen salted roads.good to hear, that is good news
what about the rear driveshaft Giubo harmonic balancer/coupling??? a lot of people seem to have these fail pretty early, some like 25-30K miles and even to owners that are NOT even tuned
here's a link to that long tread:
http://forums.vwvortex.com/showthread.php?6912758-Something-new-to-check/page5
WOW...........150K + miles??? is it a 2012 model??I'm at...wait for it...154k, picked up last month with 150k even on the clock. Tight as a drum and beautifully maintained other than the timing belt/water pump not having been done, which I just did yesterday along with the dogbone and passenger-side engine mounts. Feels like it'll go another 150k easy.
It's a 2012, yeah. Bone stock, carfax looks like it went to the dealer for services once every 10k miles like clockwork. I'll eventually get it up to stage 2+ and put some coilovers on it for auto-x rather than for going low, but nothing too crazy beyond that.WOW...........150K + miles??? is it a 2012 model??
that is good to hear that these cars are still going strong after these many miles
is yours stock or somewhat modified? if not modified are you planning on doing stuff to it?
PM sentIt's a 2012, yeah. Bone stock, carfax looks like it went to the dealer for services once every 10k miles like clockwork. I'll eventually get it up to stage 2+ and put some coilovers on it for auto-x rather than for going low, but nothing too crazy beyond that.
For the kessy problem your having you should try replacing key fob battery. It was happening to mine and I replaced battery and it’s been good sinceI was contemplating selling mine soon as I am creeping up to 72k miles. After reading some of the higher mileage guys' posts, I am thinking my car isn't even at her midlife crisis yet!
Other than issues relating to an accident, my only issues have been:
- Bluetooth acting strange. My phone would connect and disconnect every 3 minutes. After the recent IOS update, the bluetooth is working fine.
- Kessy. Sometimes the door-touch-unlock/lock system works, sometimes it doesn't.
- Backup Camera. This one kind of doesn't count, but I haven't been able to get the dang thing to work since I bought the car. (previous owner had it installed... poorly)
- Speaker. The front passenger speaker blew out and was super fuzzy. Had it replaced under warranty but it is starting to sound fuzzy again.
- Guibo. Starting to get some increased vibration at highway speeds. Sucks that I am out of warranty for this one!
Once I can get the above issues dialed, I will look forward to many more years of ownership!
AgreedFor the kessy problem your having you should try replacing key fob battery. It was happening to mine and I replaced battery and it’s been good since
