1 - 4 of 4 Posts
For some reason my hood on the drivers side will not latch all the way down. Anyone have this problem and if so, how did you fix it? I need some help here guys its drivng me crazy. Ive tried messing with the latch on the hood but its not working, im up for any and all suggestions. thanks
brett
Re: hood question (Ra)
yeah, it's either the spring-dealie that simply needs to be adjusted, or part of your cable might be sticking. adjust spring-dealie first (simply by turning it a few times), and if that fails, remove your grille to check out your cable, make sure it isn't kinked or caught (if your pass-side is still working, though, this is unlikely).
1 - 4 of 4 Posts
