1 - 6 of 6 Posts
I have a 1987 Golf GL. Only a single tone sounds when I use the horn. Is this correct or is there a second horn that is not working?
Re: horns - are they dual note? (1.8 nut)
I don't know about yours but my 92 gti has 2 seperate horns. One in front of the radiator and one tucked up behind my drivers side fender towards the front. I only saw it because i pulled my bumper off and noticed it behind a vacumn canister.
I also have an 87 Golf GL
Look in your driver side front wheel well, easier when you remove your wheel first.
Mine had 2 stock horns = dual note.
Look for dangling wires not connected to anything.
They may have just disconnected.
If not then it may have burned out.
Banned
Re: horns - are they dual note? (Crayola)
91 GTI single note and a crappy one to boot
I need some hella air horns http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
Re: horns - are they dual note? (qka2)
88 single note. Lean on it for a little long and that single note turns into a screech. Worked for me
i always thought mine was single note, until i replaced my fender the other weekend and found another horn in there.
now i wonder which one isnt working.
The european horns sound different than ours. I want one.
1 - 6 of 6 Posts
