Re: How are the rear badges attached? (gtivrx)
quote:[HR][/HR]yes double sided tape is what it is...
Good luck at peeling off the remaining sticker once you have the badge off.[HR][/HR]
You can use 3M adhesive remover (no harm to the finish) or WD40... Remember to re-wax AFTER the emblems are replace (if they are replaced)... Do not use a silicone-based cleaner or the emblem replacements (aftermarket) will not stick as well...
