How can I change the day time running lights to the fog lights?
554 Views 3 Replies 3 Participants Last post by  HIDGolf
I would like to make my DTR lights my factory fog lights instead of the low beams.
I was thinking that I could change the connections at the DTR light relay and the light switch.
Instead of the yellow wire (terminal 5) going to the low beams at the DTR light relay I could connect them to the green and yellow wire (terminal 13) at the light switch going to the fogs.
Would this work safely? Any other suggestions?
Thanks
1 - 4 of 4 Posts
Re: How can I change the day time running lights to the fog lights? (MarkF)
Cullen?
This is on a MK4, but it may give you some ideas for yout '95 http://forums.vwvortex.com/zerothread?id=170096
Re: How can I change the day time running lights to the fog lights? (BoraVR6)
id like to do the same thing , but w/ the his.
1 - 4 of 4 Posts
