How can I prep and care for these Powder Coated Wheels?
684 Views 7 Replies 6 Participants Last post by  germanrox
Should I, or can I , apply a coat of wax to these wheels prior to mounting? If so any suggestions as to what kinf wax to use? I have Meguiars at home right now.
Also, should I re-apply a wax periodically after mounting them? Can I use a polish on them to shine them up after washing my car?
I am not sure if I can treat powdercoated finishes the same way that a painted finish is treated. Thanks in advance guys. http://****************.com/smile/emthup.gif
[Modified by VR6BOPER, 2:17 PM 2-12-2002]
See less See more
2
1 - 8 of 8 Posts
Re: How can I prep and care for these Powder Coated Wheels? (VR6BOPER)
Anybody with knowledge or experience when it comes to cleaning and maintaining powdercoated rims, please give some suggestions!
See less See more
ttt
come on guys help the man out!
Re: How can I prep and care for these Powder Coated Wheels? (98vwgti)
Apply a quality polymer sealant before mounting and then keep them nice by reapplying regularly as needed.
No biggy, just don't ever let a carwash or anyone else spray them with acid cleaners or high caustic water based cleaners, they will turn them grey.
Ketch
Powder coating is painting, just in a differint way than normal paint spraying. Instead of spraying the surface and having paint go everywhere, powdercoating uses a positive and negative charge to the paint and the piece being painted. After the paint is applied the piece is baked to provide a uniform appearance that is very durable.
You can safely wax powdercoated wheels, but wax evaporates quickly due to heat and wheels get hot under normal operation. I'd personally go with a polymer like Klasse, as it will last longer. Re-apply as necessary. With Carnuba, you'd have to do it once every few days or so because Carnuba just doesn't last when heat is involved. With Klasse it would be closer to once every 1-2 months.
As far as polishing goes, just like any painted surface, you do not polish unless it is necessary. Polishing removes surface material, albeit in small amounts, but over time continued polishing will remove the paint. Powdercoating is normally stronger than regular paint/clearcoating, but it will wear thin as well. Do not use normal allow wheel cleaner on your powdercoated wheels. Take care of them like you would any other painted surface on your car.
Did that help?
[Modified by JosephShaw, 5:03 PM 2-13-2002]
See less See more
Re: How can I prep and care for these Powder Coated Wheels? (JosephShaw)
Electroplating. Like gold plating. This is how new cars are painted.
Thanks for the bump 98vwgti!
Yes your info did help! Thanks ketch, and JosephShaw! Your opinions are much appreciated. For a while there I thought everyone had abandoned the detailing forum!
So two votes for Klasse. I was looking through some of the other posts, and this product seems to be held in high regard. Can it be purchased at most hardware/automotive supply stores?
Also, I only drive my car in the spring/summer/fall, and I wash it at self serve car washes. Do you think that the soap available at these self serve drive in bays, are caustic, or acidic? The soap just smells like soap, so it's hard to tell!?!
Thanks in advance guys, I really appreciated the advice. http://****************.com/smile/emthup.gif
See less See more
2
Whoa I have the same wheels, and that's exactly what I want to do with them!!
1 - 8 of 8 Posts
