1 - 7 of 7 Posts
is it just a chip change or did they upgrade the internals of the turbo? please lemme know as I have just purchased said engine (GTI). my turbo 16v got killed in a rear end accident BTW. thanx Errol
Re: how did vw bump hp and torque for 2002? (John A)
The real answer is: Nobody really knows for sure. Ask 10 people, and you'll get 10 different answers. The bad news is that you can't even find out by buying the Bentley manual for the 2002, since it doesn't even cover the AWP engine. http://****************.com/smile/emthdown.gif
Re: how did vw bump hp and torque for 2002? (VWTattoo)
well, we know the boost was changed. that's been proven by vag-com logs.
that being said, nobody has come up with any new part numbers for exhaust / intake -- so that part hasn't been proven.
a tech from a dealer posted on here that the engines are the same hardware wise, and that if you have an aww and it blows, the suggested replacement is the exact same as the suggested replacement for an AWP.
quote:[HR][/HR]well, we know the boost was changed. that's been proven by vag-com logs.
a tech from a dealer posted on here that the engines are the same hardware wise, and that if you have an aww and it blows, the suggested replacement is the exact same as the suggested replacement for an AWP.[HR][/HR]​
Do you mean if the turbo blows?
If so then that stands to reason, it was never rumored the turbo was a different K03 type between AWW and AWP.
1 - 7 of 7 Posts
