Re: How do I bypass the supercharger?? (92VdubSLC)
remove the charger, use a 59" serp belt, screw the oil sensor into the side of the head after removing the fittings on the side of the head, either remove and plug the oil return line or put a nut and bolt through the banjo fitting. Then you have to make a piece to connect the boost return and IC pipe to the airfilter assembly
actually it looks like the G60 doesn't need to be removed to install the 59" belt. then there is no need to mess with the oil lines. But if there is a hole in the charger you should remove it
