1 - 4 of 4 Posts
Discussion Starter #1
I just purchased a MOMO aluminum shift knob, and I need some help removing the OEM one.
Has anyone done this? Is there a trick?
Jason
Re: how do i remove the shift knob? (JerseyFreeze)
lift up on plastic piece on bottom of boot, pull boot over knob. you will see a brass ring around bottom of knob on white plastic. either cut it off or bend it open. after loosening the brass ring pull up on knob. may require a bit of pressure but it will come off.
Discussion Starter #3
Re: how do i remove the shift knob? (NJ2000GTI)
Sweet, thanks.
Sounds simple enough. I'm hoping to install it this evening.
Jason
There are some how-to's in the Golf IV and Jetta IV discussion areas "stuck" at the top of the page.
1 - 4 of 4 Posts
