1 - 17 of 17 Posts
Discussion Starter · #7 ·
Re: How do i remove the valves (mrkrad)
ahh thanks didnt think about that , should be getting my head back from forrester once i send him these valves since my current ones are bent.
Re: How do i remove the valves (SSj4G60)
you JUST need to get the vavles out???
Try this...
spray the center if the VS retainer with WD40
take a socket that is a little smaller that the diameter of the VS retainer
put an extention on the socket
place wooden blocks on cement floor, place the ends of the head on blocks
place socket and extention on retianer
take BFH, hit socket quickly untile valve keepers pop out.
Works everytime. Sometimes the keepers get a lil sticky tho, use more WD40, or force http://****************.com/smile/emthup.gif
Discussion Starter · #10 ·
Re: How do i remove the valves (Dieder)
ok i got the tool now what do i do w/ it , its like a combo of a C-clamp and vice grip, so how do i did this, i tried and the valve only sticks out a little bit am i supposed to use that end to go inbetween the valve and head ?
rob you have to push down on the spring and then take off the retainers...then the spring should come up over the valve stem
Banned
Re: How do i remove the valves (BLUE NRG)
bangine the valves can bend em trust me i used to do that.i brought the valve tool from tt.it works it pretty easy.to remove and to reinstall valves. if u wana remove some valves let me know i work cheap.
Discussion Starter · #14 ·
Re: How do i remove the valves (G60247)
quote:[HR][/HR]What are you going to do w/the rest of this head??
Let me know.[HR][/HR]​
um you want it you got it,
I returned the tool cause it wasnt working at all.
king , you got mail
Let me know.
king , you got mail [HR][/HR]​
You got mail
1 - 17 of 17 Posts
