How do I slap 17's on my dub??????
432 Views 10 Replies 8 Participants Last post by  dreaminginboost
i dont really want em that big but thats the smallest they come, im gettin the tenzo ZT-6 's, anyway are there any precautions i should take and do i need some kind of suspention set up?? or bigger archs?? what o i need. thanks. http://****************.com/smile/emthup.gif
See less See more
1 - 11 of 11 Posts
Re: How do I slap 17's on my dub?????? (88gti16vracer)
well there are these 16 lil bolts....
you will most probally need to roll or trim your fenders. Make sure your offset if correct.
Re: How do I slap 17's on my dub?????? (Dieder)
your gunna need a jack too
2
Re: How do I slap 17's on my dub?????? (euroscene17)
quote:[HR][/HR]your gunna need a jack too[HR][/HR]​
hmmmm sounds technical.....
See less See more
Well. first off, what size tire are you going with? is the car lowered?
Mine are 205/40/17 and is lowered 1and a half inch. I did definitely had to trim the fenders, by using a rubber mallet and a grinder. Offset is important also. Try to keep it where it is right of the factory or it will cause much damage. Now as for tire size, depending on how low your car is or how much your going to lower it, your going to have to go with a 7" width rim. 7.5" with 205's will rub a little,215's will rub mad!!! So you'll be safe with 205's and a 7'' rim. And i would deffintely get some lug bolts, they could help.
don't forget locking ones to.
See less See more
205/40/17 yoko paradas. Tastes good, less filling they say....ZR speed rating and a hundred bucks a tire.
[Modified by JettaTournament, 4:51 AM 2-13-2002]
i have a 1 3/4" drop on my car, with 205/40/17 size tires. i cut the flat part of the fenders that jut toward the wheel with a dremel, just at the top. didn't have to do anything to the rear. no scraping. http://****************.com/smile/emthup.gif
See less See more
2
Re: How do I slap 17's on my dub?????? (duff_man2000)
quote:[HR][/HR]17s are too heavy...
[HR][/HR]​
Not if you buy Volks.
Carlos
See less See more
2
Re: How do I slap 17's on my dub?????? (iman16vw)
18's with 3.5in drop
See less See more
2
Just drop that B!
tch on fk's, take a few pics and I'll be happy to host it up on my server.
[Modified by JettaTournament, 10:58 PM 2-13-2002]
See less See more
Re: How do I slap 17's on my dub?????? (JettaTournament)
17x7 motegi M8's
205/40/17 front \
215/40/17 rear / <--yokahama A520
H&R
bonrath lowering caps
2.00" drop
rolled fenders
never rubbed
Ed
1 - 11 of 11 Posts
