1 - 11 of 11 Posts
Discussion Starter #1
I searched online and there is a special tool that I saw you could buy but I also heard a few people say that you don't have to use it, and that you could just pull them out. Well my question is do I have to unscrew the fuel line before I try to pull the injectors out and if so, how?
Also one more question, I found a random "Rubber" hose that lead to nowhere and pulled on it a little bit and it snapped clean of.. Was wondering if anyone knew what its for.
Can't see your pictures on mobile.
No, just pull out, don't unscrew. Be sure to pull the injector, not the fuel line. I think I used vice grips on mine.
Discussion Starter #3
Awesome, thanks! Do I need new O-Rings when I put them back in?
You don't have to use new o ring. They're cheap, but a set of injector seals and injector holders. Cheap easy vacuum leak fix
'81 Trek 614, '95 Ranger
Discussion Starter #10
1 - 11 of 11 Posts
