How do you install a Callaway micro fueler?
669 Views 3 Replies 2 Participants Last post by  The A1 and A2 German
1) Three elterical wires: Red, Brown and Black.
2) One vacuem line that T's off into 2
3) Put a T inline with the fuel line before the FD and run a straight hose to the nipple on the injector?
-Thanx, Dub-On!
1 - 4 of 4 Posts
Re: How do you install a Callaway micro fueler? (The A1 and A2 German)
Red - positive
Brown - Ground
Black - ignition coil terminal 1 (-) tach signal
Hook the vacuum line up to intake manifold pressure. This means it needs to be on the manifold side of any check valves, etc.
Callaway originally intended the injector to be connected to the same place as the cold start valve. Connecting after the fuel filter but before the fuel distributor should accomplish roughly the same thing though (I think - I'm trying to remember if that is regulated any differently, or if it is at regular system pressure.)
Re: How do you install a Callaway micro fueler? (vwmikelvw)
Thanx bro.
Quote, originally posted by vwmikelvw »
Any other takes on this out there? FYI, my injector is plumped into a ebow that attachs to the TB boot.
See less See more
See less See more
1 - 4 of 4 Posts
