On my 97 Gl Jetta, I took off the two clips that hold on the Distributor Cap and now I can;t get the two clips back on. What is the procedure to get both clips back onto the cap? Help, my car is stuck at Starbucks
Re: How do you put back on the Distributer Cap? (lowazzgolf)
It's tough...try to get the back one on, then press down really hard and push the front one on. Careful though, if you break one, you have to replace the ENTIRE distributor, cost me $300 Cdn to do it
Re: How do you put back on the Distributer Cap? (Red Baron Golf)
i used a flat tip screwdriver to help pop it back on.
Also, i thought id read somewhere that someone had broken one and was able to just replace the clip... i dunno though.
-tom
Re: How do you put back on the Distributer Cap? (corduroy79)
Thanks for the replies. I eventually had to take a piece of wire and hang it below the back clip and pull the wire up to make the back clip snap into place. The front clip snapped into place with some pliers. Beware the back clip!
