....the brushed stainless covered pieces that go around the radio & climate control buttons??? It looks like they were attached with a type of silicone.
Quote, originally posted by [email protected] » |
they are a whole cage.... it should come out as one... if you took the silver parts off by them self you did it wrong... |
Quote, originally posted by thread » |
And if you did remove them each go to your local parts store and get some black silicone adhesive. NOT the form-a-gasket stuff but, looks the same. Just make sure it says Black Silicon adhesive sealant. I used some today in the same area to secure the radio trim piece into place. Works great. |
Quote, originally posted by BrewDude » |
Push upward to lock them into their grooves... |
Quote, originally posted by silversport » |
Sorry, I think it's a lack of communication. I'm talking about the 2 skinny, side pieces that go on either side of the radio, not the 3-hole piece which looks like it holds 3-gauges. |
Quote, originally posted by Max Rebo » |
They can be installed individually, but to remove them, you have to remove everything around them first. If you yanked them out first, then you probably broke the small, fragile tabs on the back that lock them into place. |
