Re: How do you tell if your CV joint is shot? (bajan01)
If the axle is removed, hold the axle and try rotating the CV joint forward or backward. There shouldn't be any play at all. Try rotating it in every direction also and to see if there is play before it actually locks and starts to turn.
My rabbit had a similar problem, and it ended up being the wheel bearings. When I would jack up the car and turn the wheel, you could hear a slight grinding noise. But the bad bearing caused a constant grinding noise while driving, which doesn't sound like your situation.
-Nick
[Modified by NTRabbit, 9:25 PM 2-12-2002]
