Re: How does hill descent work exactly??? (hawc)
Without getting overly complicated, HDA keeps the Touareg under control when descending a steep hill by controlled brake applications...So, it is primarily a function of the Brake system, but other things must be in place as well...ESP must be on(another brake function), the T-Reg must be in 1st Gear; not 2nd or 3rd, for engine management...Something the current Owner's Manual is a bit vague about, and the reason behind the infamous
http://www.VWWebSource.com
disclaimer...The Owner's Manual even states that the steeper the grade the lower the gear required...Duhhhhh!!!
I should not be so harsh...
as this is, no doubt, a translation problem that occured over here...
But that is basically it...not exactly rocket science, but a lot of fun...
Modified by vwguild at 6:43 PM 7-16-2003
