how does I remove the panel under the fuse-panel?
421 Views 4 Replies 3 Participants Last post by  TWG
I've unscrewed the 3 screws that is under the steering-wheel and also pulled out the "white-clips thing" but something is stuck approx in the middle just above the middle torx screw... and I can't get it out! going to do line up a new power cable for my ICE!
But the
is totally stuck.. and I don't want to break anything!
Sometimes I hate my car ALOT
Modified by TWG at 7:25 PM 6-30-2003
See less See more
1 - 5 of 5 Posts
Re: how does I remove the panel under the fuse-panel? (TWG)
Anyone?
If I remember correctly, I pushed the panel in first towards the white clip, then pulled it out. I think there is a clip you can't see.
Its been a while, I installed my system the day after I got my car. (2 years ago on Friday.)
Re: how does I remove the panel under the fuse-panel? (Quick VW)
If its what I think you mean, theres a built-in spring clip. Once the screws are out, just pull down on the panel gently & it should release.
Re: how does I remove the panel under the fuse-panel? (Cosmic631)
Hm...
Will give it another try...
1 - 5 of 5 Posts
