1 - 3 of 3 Posts
Well I finally got ahold of some loot to FINALLY get a wideband and some other parts.
Currently im just running stage 1 6psi with 30# injectors OBD1 coilpack.
Im not sure if theres a need to drop the compression just for 9psi. Ill probably be running the 30# setup for a while longer.
so if were to run:
9lb WG spring
wideband
innercooler
would that be a safe setup? btw im running the MK4 HG. im not sure if that makes is 10:5:1 or 10:8:1.
BTW ive had serious issues with my current setup in the past. But ive fix all the issues. mainly due to a bad 02 sensor.
Re: How does this setup sound?(obd1 vrt) (hoodita)
Just be careful as you get closer to the limits of the fueling. You need a little extra fuel for the bump in compression. I would think that 9psi would be fine though. Keep an eye on your wideband, maybe install a water/meth setup for the heat
Re: How does this setup sound?(obd1 vrt) (KubotaPowered)
Thanks for the advice. ill most def ad meth. http://****************.com/smile/emthup.gif
1 - 3 of 3 Posts
