Hi, im having issues with turn signals and are not used to "modern" car electronics.
Im used to owning a old 90's car for years which is easy to handle and work on.
The Mk5 Gti seems very different.
Just from googling im not sure if there is even a relay.
I also heard about modules that control electronics like blinkers etc instead so im quite confused how this work out.
Im actually trying to solve a problem with ONE blinker wont work.
And that is the Front right one, while all the others works.
Here is how far ive come:
Bulb's fine.
Connector for bulb is fine.
Harness for the entire healight also fine.
However, the blinker wire i can measure only 0.5volt max.
While other blinkers of course are doing their proper job, around 12volts.
I measured the blinker harness and the entire headlight harness and still cant get any higher readings.
Next i must figure if the problem are under the hood, or actually inside the car behind the firewall.
So i want to know, where and what does this wiring loom on the passenger side go to? (LHD CAR)
Where should i go next?
My plan was, if i could get proper readings from inside the car, behind the firewall, i could probably say the problem
was in the engine bay, which would save me time and be an easier job.
I just dont understand what is controlling these turn signals and where i find this unit.
Bulb's fine.
