Re: How many PSI can these things run? (Y2KJTA)
u can go 10psi with everything stock (compression, internals, etc...) pretty well...15psi...lower compression via copper head gasket or JE forged pistons, upgrade rods, cranks or whatever...i'm sure other guys in here knows the detail...but generally, these sohc's are pretty tough if not tougher then the dohc's...the cam don't matter cuz the only actuates the valves and has nothing to do with internal compression...however a moderately more radical then stock cam (260) helps the flows...but too radical of a cam will not work well with a turbo...the most common problem is fueling..running too lean with higher boost etc...
