this is what happens when you have 22 psi and to much advanced timing
Quote, originally posted by slomofo. » |
well, with 10:1 factory compression, probably 6psi. maybe 9psi intercooled. i'm not the expert, that's just my guesses. either way, with a name like advanced technologies, shouldn't you know the answer
Quote, originally posted by advanced technologys » |
this is what happens when you have 22 psi and to much advanced timing |
Quote, originally posted by TheCunningLinguist » |
COOL!! |
vwgroundzero said:someone in Conn. is running 20 or so psi on a stock aba, with sds from what i know. has done so successfully for a while, then blew his motor a day before waterfest, and had another motor in the same night to make it to waterfest.QUOTE]
thats dedication and hard work http://****************.com/smile/emthup.gif
Quote, originally posted by WhenDubsCry » |
you'd think so.....except his name is advanced technologys, lol. ![]() ![]() |
Quote, originally posted by vwgroundzero » |
someone in Conn. is running 20 or so psi on a stock aba, with sds from what i know. has done so successfully for a while, then blew his motor a day before waterfest, and had another motor in the same night to make it to waterfest. i take it 20psi is doable, but not reliable. |
Quote, originally posted by JoshGarman » |
n00b question....ABA means??? Josh |
