Quote, originally posted by dackar » |
How much boost should the 68 mm pulley produce in a good P&P head ( mfa ) in a stock 90' G60 (stock piston, cams, crank pulley, etc...)? |
Quote, originally posted by TexasCorradoG60 » |
I have a stock head and cam and see 17-19 PSI on any given day with my 68MM pulley.....just before 6500 RPM and no bouncing off of the rev limeter.
Quote, originally posted by RockHarder » |
I hit 15 psi with a 68mm before I got a rebuild, afterwards with a RS port I hit 13 psi. I have been trying to find if there is a leak, but I can't find any. |
Quote, originally posted by G60ING » |
boost leaks are the enemy |
some times when you port you loose psi but gain cfm |
Quote, originally posted by IMNOBUG » |
this is correct...PSI is a way to measure resistance. porting with increase CFM but lower PSI |
