Re: How much brake fluid do I need? (rs4-380)
Quote, originally posted by rs4-380 » |
you only need one liter to bleed.
never use brake fluid that has been previously opened.
if you bleed with the pressure bleeder, you really don't need to worry much about bleeding the clutch. |
Yep. I bought 2 bottles of Super Blue (clutch still fine after a year) and used only one of them.-- I have heard of issues using Super Blue...something with the dye (and the dye makes it not DOT approved also)
1 liter for me with a pressure bleeder.
Instructions?
Use a turkey baster to remove the old fluid. Pour fresh fluid in reservoir. Pour the rest in the bleeder
Jack car up and support with jack stands
remove wheels (good time to rotate them).
Pressurize the bleeder
Start bleeding, passenger side rear, then driver rear, then passenger front, then driver front. Bleed each one, one at the time, usually in that order, until you see the new fluid with no bubbles. Everynow and then check the bleeder for pressure and top the bleeder as necessary
Modified by GT17V at 10:40 AM 9-9-2005
