1 - 8 of 8 Posts
Re: How much fuel pressure in our fuel lines? Billy T? (drm916)
well, the stock FPR is 3 bar. Haven't done a gauge yet. FWIW, I am still running the 3 bar FPR.
Re: How much fuel pressure in our fuel lines? Billy T? (1.BillyT)
i need to know if I tap my line going into the fuel rail....How much PSI will be there?
[Modified by drm916, 1:15 PM 2-11-2002]
with no vac attached it should be 3bar, Eg about 44psi. figure 5-8psi less with vac. What line are you trying to tap into the fuel rail?
-Mike P
[Modified by tyrolkid, 1:36 PM 2-11-2002]
Re: How much fuel pressure in our fuel lines? Billy T? (wolfsburg_de)
quote:[HR][/HR]It should also rise as boost increases, right? So:
3 bar * 14.7 psi = 44.1 psi
with 1 bar of boost:
4 bar * 14.7 psi = 58.8 psi[HR][/HR]​
That assumes the regulator is 1:1 boost referenced. Actual pressure at the injectors must be reduced by level of boost present in the intake manifold........10lbs of boost in intake manifold reduces actual pressure by approximately the same amount.......
quote:[HR][/HR]I'm not sure I follow. If the fuel pressure goes down as the boost goes up, then there is less differential pressure across the injector, so less fuel gets into the intake runners for a given injector pulse width.[HR][/HR]​
Bump the pulsewidth or use a regulator higher than 1:1....
1 - 8 of 8 Posts
