Re: how much power can a stock '91 G60 gearbox take ? (JRG60)
The syncros can go at any time with stock HP or upgraded hp
The diff's rivets like to stretch and then eat a hole in the tranny casing causing the tranny oil to leak out and force you to buy a tranny housing. So if you take the tranny out you should at least but in a Bolt kit on the diff. VW even sells a bolt kit because they know of this problem happening with stock HP cars. At the same time you should install a LSD. Frank
