does anyone have the diy saved on their computer, i couldn't find it on cached google and since vortex **** out all the archived threads im outta luck
Youlll need a 4-channel hi-low converter to tie into your stock amp in the car to pass the low signal to you sub for the bass while your speakers will play mostly your high and mids.I'd like to know as well. 2001 Jetta
That would be a Hi-low conveter. That you would tie into the wiring harness that plugs into you stock amp for you door speakers for the moonsoon system.I just put one of these in, connects to your speakers for your RCAs
http://www.amazon.com/PAC-SNI35-Adj-Line-Converter/dp/B0002J22AA
to keep the factory wiring harness clean, I ordered both a male and female factory connector from www.enfig.com (christian) and then tapped signal from the rear speaker leads to provide high-level signal to a converter then to the amp.......but then I change my system.That would be a Hi-low converter. That you would tie into the wiring harness that plugs into you stock amp for you door speakers for the monsoon system.
Or you can do taht and take the install a few steps farther but if you looking for a simple install i can give the a write up for it or if you want to do it the way hes talking about i can write that up too.to keep the factory wiring harness clean, I ordered both a male and female factory connector from www.enfig.com (christian) and then tapped signal from the rear speaker leads to provide high-level signal to a converter then to the amp.......but then I change my system.
I now have a complete DSP bypass created by using a blown Monsoon amp....I pulled the input connector from it and used it to tap the signal from the HU to a JBL Clean-sweep, from there it's all lo-level to the amps, then use the output connector from the Monsoon amp to plug back into the factory wiring harness for the front and rear speakers, with the sub directly connector to the sub-amp.
clean factory looking HU with nothing looking aftermarket.....amps hidden where the spare was, and only the sub is visible once you open the hatch.
Trigger wire explain for me so i can help you out.my car already has the high/low installed, the p/o did it. i was looking for where it said how to hook the trigger wire from the cd changer
