How to change plugs
485 Views 10 Replies 7 Participants Last post by  VR6 Mk3
I know this might seem like a silly question, but how does one change spark plugs? I think I can do this. I am only really worried about gapping the plugs correctly. Which plugs are the norm? Where can I get them and do they come pre-gapped?
Thanks in advance,
Bobful
1 - 11 of 11 Posts
Re: How to change plugs (Bobful)
they should be pre gapped when you buy them...stock spark plugs you would get from your dealer are recommended...there should be a tool to get at your plug wires attached to your hood prop rod.
tt has plug wire tool if u need one.
See less See more
Re: How to change plugs (J3GTI)
There is a special tool to remove the wires? I thought all you had to do was pull them off.
-Bobful
Don't put the plugs in too loose either, I had one pop out while driving and my A2 4 cyl turned into a 67' bug! whoa!
Re: How to change plugs (VR6 Mk3)
quote:[HR][/HR]they should be pre gapped when you buy them...stock spark plugs you would get from your dealer are recommended...there should be a tool to get at your plug wires attached to your hood prop rod.[HR][/HR]​
thats only on the vr6s
Re: How to change plugs (JetTAFLiTe)
I would check the gapping and get new wires at the same time, you'll do damage to the stock wires when you try and get them out, at least in a 2.0.
Chris
Re: How to change plugs (Chrismilli)
You may want to Do one plug at a time so as not to confuse which plug wire goes where. (I have done this, not fun!!!)
There is a special tool to pull the plug wires off. On a new VR6 equipped car the plastic version of the tool comes snapped onto the hood prop. If the car is used it may be missing. It isn't mandatory but it does reduce the chances off damaging the connection between the wire and boot. No sense buying new wires if you don't need them when the tool is about $12.
Pull plug wire off of plug. Use a spark plug socket that has an insert which grips plug to aid in removing it. You will also need an extension or two.
If you meet serious resistance while trying to remove plugs and penetrating oil and modest pressure on a breaker bar or pipe do not allow the plug to come loose, consult a professional. A broken plug is NOT what you want when it is still screwed into the head. I know this from experience.
Double check your gap with a gapping tool (sometimes preset gaps can be wrong). Gap for the VR6 with OEM plugs is 0.7mm (0.024 in.) multiple electrode plugs do not require any gapping. Bosch +4 plugs are not recommended by many for the VR6.
Apply a very small amount of anti sieze compound to the threads only on each plug. This helps avoid problems the next time you replace the plugs.
Carefully, so as not to cross thread, screw the plug into hole. Using a torque wrench, tighten each plug to 25 Nm (18 ft-lb). A torque wrench isn't mandatory but it sure helps me sleep at night.
Replace spark plug boot securely.
Repeat for each cylinder.
Original VR6 plugs were NGK: BKR 5 EKU
Have fun.
See less See more
Re: How to change plugs (Bob Roberts)
Bob,
Thanks for the great info. I think I will give it a try.
thats only on the vr6s[HR][/HR]​
Yes, well his sig said he had a VR6....
1 - 11 of 11 Posts
