What is the procedure to disable the horn beep when locking the car (without using VAG-COM)?
V VWGolf1 · Registered Joined Nov 1, 2010 · 5 Posts Discussion Starter · #1 · Jul 24, 2011 Only show this user What is the procedure to disable the horn beep when locking the car (without using VAG-COM)?
P PolakTDI · Registered Joined May 26, 2011 · 156 Posts #2 · Jul 24, 2011 Only show this user Find the horn, stab it with a screw driver...your results may vary. :what: Only way is to do it with vag-com.
S Seff56 · Registered Joined Oct 19, 2009 · 116 Posts #3 · Jul 24, 2011 Only show this user it should be in the cars menu on the dash
G GREYTRACK · Registered Joined Mar 5, 2007 · 524 Posts #4 · Jul 24, 2011 Only show this user Seff56 said: it should be in the cars menu on the dash Click to expand... Vag com
M MANU01 · Registered Joined Aug 7, 1999 · 1,998 Posts #5 · Jul 24, 2011 Only show this user Highline = in dash menu (I think it's called "ATA Confirm" or similar)
J johnnyR32 · Registered Joined Aug 31, 2004 · 41,143 Posts #6 · Jul 24, 2011 Only show this user GREYTRACK said: Vag com Click to expand... :thumbup:
A ArtieMacKinlay · Registered Joined Jul 30, 2010 · 707 Posts #7 · Jul 24, 2011 Only show this user Mine has it in the dash menu.
P phd-12v · Registered Joined Jun 13, 2001 · 1,430 Posts #8 · Jul 25, 2011 Only show this user its directly above the right front wheel. http://www.youtube.com/watch?v=TEc7AGf4ZHY You can unplug it and put in a normal siren from an alarm. I used an Alpine siren on mine.
