1 - 4 of 4 Posts
i have several ideas ....
but i was thinking to lower the compresion with 2 headgaskets and torque the livin shi* out of them ....
is this a good idea or bad idea ???
i have a complete CIS-E setup ...
now ... can i put a rezistor at the O2 sensor so it will lie to the ecu about the A/F mixture ....
if yes the what value rezistor ...
if no ... please explain ...
hopefully i will "dream off" some other ideas as well ....
actually i did see myself doing these things im my dream ...
Re: how to lower compresion and trick ECU for extra fuel ??? (VW_Adrian)
Not sure why you would torque the poop out of the head gaskets. More torque is probably a bad idea.
As for tricking the ECU, the full throttle switch probably already does what you want.
If you wanted to throw a resistor in there somewhere to make the ECU think you were running lean, I think you would need to pull the O2 wire to ground, but this is far from a controllable enrichment scheme.
Not sure what injection setup you will use, but the "16v power module" is probably a good place to start.
-Steve
Discussion Starter · #4 ·
Re: how to lower compresion and trick ECU for extra fuel ??? (jcorallo)
lowering the compresion and adding extra fuel is for the turbo setup which will follow after all this is complete ....
1 - 4 of 4 Posts
