How these work with VW/Bosch CIS-E
Quote, originally posted by johnnyGO » |
Roger that... I was just thinking about it while I was going through this topic, since in a sence the module is basicly doing the same thing as the WOT switch ( IE: richening ) except the module can be adjusted.
That also brings up another point, wont the module make the car way to rich at full throttle or when the WOT switch is engaged or does the module over ride the WOT?
Modified by johnnyGO at 10:10 PM 3-19-2009 |
The "modules" that connect to the CTS work this way...
At WOT the ECU operates open loop - that is, it no longer uses the O2 sensor input to drive fuel management. Instead the ECU refers to an internal algorithm that generates predefined currents for the DPR based on load (vacuum), engine temperature, and RPM. This factory enrichment is only slightly rich (Lambda around .95) when the engine is warm and seems intended to help prevent pinging and not so much to produce max power - which would require Lambdas around .85.
The above enrichment modules use the WOT switch output voltage to switch in a higher resistance to the CTS ECU input, making the ECU think the engine is colder and it in turn calling for higher DPR currents. This method of fooling the ECU can drive the Lambda well below the .85 Lambda power optimum even with highly modified engines. I have seen lambdas of below .7 (about 10:1) and know the control had range to go much further. Somewhere below .7 one risks washing down the cylinder walls with fuel because it will not all burn, risking ring wear and fuel in the crankcase.
According to Probst in his book, some of the Bosch KE-Jet ECU's will not respond to sudden changes to the CTS input and this technique will not work. My experience with the KE-Jet modules for the RD and PL engines is it works.
In my experience the vacuum input has a small effect on ECU enrichment, and it is not enough to fullly compensate for the decreased fuel enrichment needs of small throttle openings when WOT is switched on.
I also found that a given resistor value will not produce a constant Lambda across the RPM range. It isnt too far off on a stock engine but as modifications are added in (cams, valves, P&P intakes and exhausts) the error increases. Thus, with my race RD engine I could dial in my desired .85 for a single RPM on a given day at a particular altitude (I hillclimb and the car usually changes elevation a thousand feet, more or less, in a run) but it was in error otherwise...sometimes by more than .15. The technique of using a pot or even a pre-determined fixed value resistor (a.k.a. the TT module) can work real well for road racing where a fully warmed engine is kept in a narrow power band at a more or less constant elevation. And it may even be set up to be tweaked by the driver from the cockpit using an EGT sensor on the long straights.
The TT module uses a safe value when selected per their directions that more or less works across a wide range of conditions because it doesnt try to enrich too much (somewhere above .85).
Dialing in a suitable resistor value for a given DIY project that gets Lambda as near to .85 as is safe (no excursion below .7 or over .95) requires a wideband O2 sensor and monitor/logger - or better yet some dyno time. Having had an Innovate LM-1 for a few years now I consider it as valuable as a good helmet and the shop manual. Once dialed in, some racers will note the EGT and strive to maintain that temp thru small adjustments of the pot while racing.
Modified by wclark at 12:26 PM 3-20-2009
