1 - 7 of 7 Posts
· Senior Member
Re: how to program vallet key (weenerdog3443)
ONLY a dealer can program a key through GEKO
· Senior Member
Re: FV-QR (weenerdog3443)
Quote, originally posted by weenerdog3443 »
ive had plenty other ppl say otherwise... anyone else wanna chime in
you heard wrong. IF you have the SKC......
PER ROSS-TECH:
http://www.ross-tech.com/vag-c....html
B6 4mo | fc3 Si
FV-QR
you need vagtacho(gets the 4 digit key from your car) + vagcom
Key Matching
Prerequisites:
* Battery voltage at least 12.0 V. We strongly recommend the use of a battery charger.
* You can match up to 8 keys.
* All keys are either new or were adapted to this car (IMMO-ID) before.
* While adapting each key, make sure to place the other keys away from the ignition lock (reader coil). The passenger seat is an adequate place.
* If all Keys are new OR the first inserted Key is new, the Ignition will NOT switch ON with this key.
o Put the first Key into the ignition Lock, but do NOT switch ON the ignition.
o Press and Hold the Brake Pedal for 20 Seconds to wake up the Diagnostic Databus.
[Select]
[05 - Acc/Start Auth.]
[Meas. Blocks - 08]
Select Block 022.
[Go!]
The value in field 3 must be 1. If value is not 1, the key is not capable of being adapted to Immobilizer.
You can check each key in this manner.
Select Block 023.
[Go!]
Make sure the shown lock times in field 1, 2, 3 and 4 are 0 (each field represents a time in minutes).
* If the lock times are NOT 0:
o Do NOT switch off the ignition!
o Allow the car to sit for AT LEAST the number of minutes that were indicated by the fields 1-4.
[Done, Go Back]
[Sec. Access - 16]
There are 2 possibilities how to enter a PIN, choose the one that applies for you.
* 4-digit PIN
o Enter zero followed by the 4-digit PIN. For example, if your PIN is 1234, enter 01234.
* 7-digit PIN
o [Use 7-digit PIN/SKC]
o Enter the 7-digit PIN, Date on which the PIN was generated by the dealer, along with the Workshop Code (WSC) and the Importer number of the dealer that generated the code.
o [OK]
o VAG-COM will validate the data you have entered and return you to the Login screen, where the Login Code will show as "XXXXX".
[Do it!]
[Adaptation - 10]
Enter 21 in "Channel Number".
[Read]
The "Stored Value" is the number of keys currently matched.
Enter a "new value" corresponding to the total number of keys to be matched, including any existing keys.
The old keys are automatically being cleared.
[Save]
[Done, Go Back]
[Close Controller, Go Back - 06]
* Switch Ignition OFF and remove Key, Steering Lock should engage.
* Insert first Key again and switch Ignition ON.
* The Warning Light for the Immobilizer will light up for ~2 seconds, then go out. Switch Ignition OFF and remove Key.
* Repeat the following steps until all keys have been matched:
o Switch Ignition OFF and remove Key, Steering Lock should engage.
o Insert next Key to Ignition and switch Ignition ON again.
o The Warning Light for the Immobilizer will light up for ~2 seconds, then go out. Switch Ignition OFF and remove Key.
Note: The above steps after saving the adaptation, should not exceed 60 seconds withing matching 2 of the keys and having one key in the ignition should not exceed 30 seconds.!
Modified by Soundwave_vr6 at 9:12 PM 3-22-2010
1 - 7 of 7 Posts
