How To Remove the .:R32 ECU (five-steps + photos)
Quote, originally posted by gabedibble » |
How To Remove the .:R32 ECU in five-steps: ALBUM : gallery =============================================== Step 1a: Battery must be disconnected [Make sure you have your Radio 'CodeCard', if you have this disconnected for too long, you may need to enter the Monsoon unlock-sequence] Step 1b: Move Negative post using 10mm socket to plastic clip on side ![]() ![]() Step 2a: Remove these from each side of the bay Step 2b: Pull off the rubber seal ![]() ![]() Step 3: Pry up the plastic cover to show components behind it ![]() Step 4a: Using your finger tip or a scew driver, carefully pull the tabs on each side of the ECU outward Step 4b: Once both tabs are fully out, the two connectors will Easily pull off ![]() ![]() Step 5: As shown here, slide the ECU forward and then carefully handle it ![]() =============================================== ALBUM : gallery |
