If you clicked [Save] then the file should be stored here on your PC (assuming you're using VCDS Release 908.2 and it's installed in the default directory):
C:\Ross-Tech\VCDS\Logs\
Thanks. :thumbup:
Thursday,17,June,2010,15:33:59:43936
VCDS Version: Release 908.2
Data version: 20100326
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Control Module Part Number: 1C0 907 379 M
Component and/or Version: ESP FRONT MK60 0102
Software Coding: 0019970
Work Shop Code: WSC 24140 444 58899
1 Fault Found:
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication
Chassis Type: 9M - VW Jetta IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: 3VWVH69M93M123415 Mileage: 99270km/61683miles
Address 01: Engine Labels: 022-906-032-BDF.lbl
Part No: 022 906 032 CS
Component: 2.8-LEV-Mj03 G 1482
Coding: 00032
Shop #: WSC 07458
3VWVH69M93M123415 VWZ7Z0B6206263
No fault code found.
Readiness: 0000 0000
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019970
Shop #: WSC 24140 444 58899
1 Fault Found:
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 04 AIRBAG VW61 0202 0001
Coding: 12340
Shop #: WSC 00066
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 J
Component: KOMBI+WEGFAHRSP VDO V64
Coding: 07234
Shop #: WSC 00000
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway KCAN 0001
Coding: 00006
Shop #: WSC 00028
1 Fault Found:
49-00 - No Communications
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00028
Part No: 1C1959801A
Component: 1H Tõrsteuer.FS KLO 0009
Part No: 1C1959802A
Component: 1H Tõrsteuer.BF KLO 0009
Part No: 1C0959811A
Component: 1H Tõrsteuer.HL KLO 0009
Part No: 1C0959812A
Component: 1H Tõrsteuer.HR KLO 0009
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-00 - Implausible Signal
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 E
Component: RADIO 3CP 0004
Coding: 00033
Shop #: WSC 00001
1 Fault Found:
00856 - Radio Antenna
36-00 - Open Circuit
End ---------------------------------------------------------------------
