1 - 1 of 1 Posts
HPA DSG Performance Program: NEW! * Stage 4 *
Since HPA introduced the enthusiast community to the tuning potential of the DSG in early 2009, we have continued to refine and develop our stage 3 offering; setting the bar in DSG performance.
This past March while at the Texas Mile, we successfully tested an advanced concept where we synchronized the S mode with the dyno curve of the engine. The alignment of the shift sequence to the engine’s peak power resulted in a documented 13mph bump in top speed at the mile. This custom matched shift point feature, coupled with an expanded thermal range for the oil temperature, has opened the door for the launch of our Stage 4 offering.
For DSG equipped cars with modified Forced Induction applications, or those boasting 450hp+, this Stage 4 offering is a MUST!
Stage 4 Features:
Expanded Oil temperature range [/blue]to support long sustained wide open throttle runs without engaging limp mode.
Custom Synchronized “S” mode matched to your supplied engine power profile to maximize power band at each shift point.
Revamped Clutch engagement curve to allow better grip with either the OEM clutches or our aftermarket upgraded versions.
Unrestricted Torque Limiter lets you radically increase or completely eliminate the DSG torque limiter; empowering you and your engine tuner with the latitude (with associated risk and responsibility) to explore the upper limits of your hardware’s performance.
Remapped “D” mode features a staged up-shift sequence until 6th gear is reached; offering a more natural and intuitive feel for driving around town. This pattern better supports brief acceleration blasts without the need for aggressive downshifts which can be very abusive on the gearbox and which erode the initial impact of the power band when looking to overtake.
This customized Stage 4 software is regularly priced at $2495… Introductory Offer until the end of July only $1995
How to Buy:
1) On Location at HPA facility or at special events:
A limited number of Stage 3 / 4 flashes will be available by evening appointment only at Waterfest 2010 // Englishtown NJ // July 17-18
2) Have your Mechatronic unit Bench Flashed by HPA
3) New… Direct Port At Your Door through our loaner tool program
4) Visit one of our Dealers
Note: The Stage 3 and 4 DSG upgrades are not transparent to the dealership; and are effective the moment the flash is complete.
For more information, please feel free to contact us at 604-598-8520 or [email protected]
1 - 1 of 1 Posts
