1 - 10 of 10 Posts
KW SHS Coilovers for Mk7
Developed in conjunction with the engineers at KW Automotive, the team at HPA Motorsports provides an out of the box coilover solution that is preset to perform.
HPA’s SHS coilovers offer an unmatched balance between handling and comfort. All SHS applications are based off KW’s twin tube low pressure damper design. Embracing KW’s patented valve technology, the high-speed dampening characteristics remain similar to OEM offering a near factory comfort level, while the low speed dampening power is increased to eliminate pitch and roll associated with heavy braking or corner entry. Each application features linear race springs on the front and progressive barrel springs on the rear.
SHS is an ideal suspension solution for the enthusiast looking to gain better control at corner entry on high-speed sprints, yet uses their car as a daily driver in the harsh real world environment.
Key Features:
  • Stainless steel construction guarantees the height adjustability won’t be lost through commuting on salt covered winter roads (KW INOX technology).
  • Self- centering integrated dust boots, which keep the winter sand and debris from damaging the piston rod seal for long life.
  • Stainless steel impregnated composite spring seats offer easy ride height adjustment all season long. No binding conventionally found with aluminum seats.
  • Race springs are EPS powder and zinc-phosphate coated for long life.
  • Springs are made from chrome-silicon steel 54SiCR6 offering higher carry capacity with less material than standard steel wound springs.
  • Height adjustable on all 4 corners
  • Spanner wrenches included for adjusting ride height
  • 1 Year manufacturer's warranty
Lowering Range:
Part # HPA-212 – Mk7 SHS Coilovers
Applications: Mk7 GTI, Mk7 Golf R
Front 10-45mm
Rear 20-50mm
SHS Coilover kits are normally built on a per order basis in KW Germany, and then drop shipped direct to our customers.
For a limited time, HPA has inventory of these specific Mk7 kits on hand and ready to ship. Competitive shipping rates to both Canada and the US are available.
Please specify whether or not your Mk7 GTI / Golf R is equipped with VW’s Electronic Dampening Suspension setup. If your car has this feature, an EDC (Electronic Damper Cancellation) Kit is available, sold separately from the SHS Kit, which will allow the SHS Suspension to be installed in the car without triggering a fault code / dash light. This EDC Kit does NOT allow for the retention of the selectable factory “Sport” suspension settings.
Additional information on HPA's SHS Coilovers can be found here.
If you have additional questions regarding these or any other HPA products, feel free to IM or e-mail us directly.
To order any of our HPA or KW performance products contact HPA Motorsports at 604.888.7274 and place your order. Visa and MasterCard are accepted, and PayPal can be set up upon request.
Getting mine installed this week! Should have the car back by next week (lots of stuff getting installed at Smith VW).
Can't wait.
1 - 10 of 10 Posts
