Late last year we released our 6 piston front big brake kit for the Mk5/6 applications.
Earlier this year we release our 4 piston rear kit with integrated park brake.
Now we'd like to give you the chance to purchase our complete braking package for your Mk5/6 application.
The HPA BBK is designed in conjunction with BAER Brakes and proudly made in the USA.
Includes:
Features:
Price: US$4995.00
Key Design Elements:
WHEEL FITMENT: Unlike most Big Brake Kits, the HPA system is designed to fit behind the OEM 18" GTI, GLI, or Golf R wheels without any spacers. Note: Factory dust shield must be removed to accommodate larger rotor.
WEIGHT SAVINGS: This kit shaves 6 pounds of rotational mass per rotor, which results in improved acceleration and deceleration, and a total of 32 pounds of un-sprung weight for improved suspension function.
CALIPERS: CNC machined from billet aluminum, the fixed 6-piston caliper and is designed to increase rigidity, improve braking efficiency, and improve pedal feel. Featuring internal crossover pipes, these calipers have a sleek streamlined look with no fragile external components. Pistons are sized to HPA specification with exact piston bore for perfect front and rear balance. Piston seals protect from dust, weather, and pressure to meet DOT spec.
ROTORS: Two piece floating rotor with directional curved vanes, and HPA curved slots. Hats are anodized CNC machined aluminum, and discs are zinc-plated for corrosion protection.
PADS: The ceramic compound pads included with the kit are suitable for street and mild track use. They create minimal brake dust and are relatively quiet. Sharing the same profile as Corvette C5/C6, there are many different replacement options available on the open market. Note: the OEM pad wear sensors are eliminated.
For more information or to place an order, please give us a call or visit: http://www.hpamotorsport.com/bbk.htm
HPA MOTORSPORTS INC.
Phone: 604.598.8520
Email: [email protected]
Includes:
- Front 6 Piston Radial Mount Caliper
- Rear 4 Piston radial mount caliper
- Slotted Two Piece floating Rotor 355mm x 32mm thick
- Slotted two-piece floating rotor 335mm
- Rear features integrated backing plate w/custom drum e-brake
- Custom cables
- Caliper Brackets
- Ceramic Pads
- Mounting Hardware
- DOT approved Direct Fit Stainless Steel Braided Brake Lines
- Brake Bleeding Accessory
Features:
- Clears OEM 18" Wheels with NO Spacer Required
- Un-sprung Weight Savings of 16 lbs. Per Side, 6 lbs. on the Rotational Weight of Each Rotor
- Choice of Red, Black, Silver or HPA Blue
- Readily Available Replacement Parts
- One Year Warranty
Price: US$4995.00
Phone: 604.598.8520
