Linden VW Motorsports is proud to be the Master Distributor for HPA Motorsports. We are happy to offer 2 of their most popular parts with FREE PRIORITY SHIPPING in the Continental USA.
HPA 02M Transmission Short Shift - $149 Shipped!
BUY ONE HERE
With designs for the Mk4, Mk5 and Mk6 platforms, these versatile pieces of hardware can be set up on one of two different positions to suit your preference: a sporty 20% reduction in throw or a more aggressive 35%/40%.
The perfectly balanced shifter counter weight gives each shift a precise and positive engagement and greatly improves the feeling over the sloppy stock shifter.
The bright zinc plated finish ensures that the stock appearance of your engine compartment is maintained while protecting the casting from corrosion.
Includes threaded pin / ball connection for connecting the shifter linkage. Easy to follow installation instructions are available upon request.
HPA Motorsports Lower Motor Mount - $189 Shipped!
BUY ONE HERE
Our upgraded mounts reduce motor flex to improve torque transfer to the drivetrain, and prevent excessive movement under hard acceleration. Shifter engagement is faster and easier and stability is improved. These mounts will solidify the engine's connection to the chassis while still isolating its vibrations from the cabin.
HOW DOES IT WORK?
The unique Core Interlock design was born to balance sensitive chassis harmonics while maintaining a comfortable feel of the engine at idle.
Unlike other urethane inserts which merely reinforce the OEM rubber mount; this is a completely re-engineered one stop solution that will control the engine’s motion without the need to install aftermarket side mounts.
