Status
Not open for further replies.
1 - 3 of 3 Posts
APR defiantly has not come with a shortage of products for the 2015+ year MQB Chassis cars. And, the APR Oil Catch Can for the MQB EA888 1.8T/2.0T MS100100 is another great product that is now available through HS Tuning. The APR Oil Catch Can System is designed to prevent excessive crankcase oil vapors from entering the intake system while the engine is under boost. In doing so, the system helps reduce oil pooling in the intercooler hoses, carbon buildup on intake valves, and the decrease in octane caused by oil vapors. Overall, making sure that your engine is happier, and more efficient!
Quick Facts:
  • Drains in seconds - No need for tools, removal/disassembly to drain the can.
  • Four-stage baffling system - Excellent oil droplet capturing properties.
  • Compact, two-piece billet design - Easy disassembly for recommended annual cleaning.
  • Abrasion resistant Buna-N lines - Resists oil degradation, kinks and abrasion with an OEM appearance.
  • OEM Norma fittings - Makes install and removal simple with an OEM appearance.
  • Discrete hose routing - Hoses are routed out of sight for an attractive install.
  • EA888 MQB Compatible - Fits all 1.8T/2.0T EA888 Gen 3 MQB vehicles equipped with APR’s Carbon Fiber Intake System.
  • Catches oil - Oil pools in the can, not in the intercooler piping.
  • Reduces carbon buildup - Fewer oil vapors entering the intake tract helps reduces carbon buildup on the back of intake valves.
  • Increase performance - Helps to reduce airflow restrictions and octane robbing oil vapors.
This is a great catch can system, and the quality is next to none! This is a must have product for anyone with an MQB Chassis car, who is a fan of APR products, or who is simply looking for the best!
If you would like to read more about this product, Please follow this link to our website, to order! - CLICK HERE TO ORDER!
NOTE: This product can only be paired with the APR MQB TSI Carbon Fiber Intake System CI100033 - CLICK HERE TO LEARN MORE!
1 - 3 of 3 Posts
Status
