Status
Not open for further replies.
1 - 6 of 6 Posts
Does your 2.0T TSI engine still have the early style tensioner? If so, save yourself the hassle of an unexpected and expensive repairs that could cost you greatly by replacing it with the new style tensioner. Our timing chain tensioner kit comes complete with everything you need to replace your tensioner, including sealant, the updated tensioner (of course!), a new timing case cover with gaskets, and all the one-time use hardware that is required. The parts are OEM, the exact parts your local dealer would use, so proper fitment is assured. We strive to make sure out kits are the best on the market, and will fit the your needs and budget. Please feel free to reach out to us if you have any questions at [email protected]
Kit Includes:
  • Updated Timing Chain Tensioner
  • Lower Timing Case With Crankshaft Seal
  • Sealant For Lower Timing Case
  • Upper Timing Case Gasket
  • Camshaft Position Sensor Gasket
  • Lower Timing Case Bolts (x15)
  • Vibration Damper Bolt (x1)
  • Engine Mount Bracket Bolts (x3)
  • Engine Mount To Bracket Bolts (x2)
  • Engine Mount To Chassis Bolts (x2)
Interested in Purchasing this Kit? - BUY HERE! $329.99
Updated Tensioner Only? - BUY HERE! $63.64
Timing Case Cover Only? - BUY HERE! $189.00
Do you sell or rent the special tool that holds the cam drive sprockets (behind the crank pulley) in timing alignment while the crank pulley is removed?
Hello! - We can sell you the Cam Lock tool for $55 + Shipping. If you would like a full tool set for the job, you will be looking at $225.00 Please feel free to contact me with any questions you might have.
Thanks!
Discussion Starter · #6 ·
If your car is a 2012 Model Year, or lower, Checking your timing chain tensioner is always a good idea. With out the update, you can face thousands in repair bills, if your timing falls out of line. Fortunately, our in house kits made entirely of OEM parts is the best and most reasonably priced solution using all OEM parts.
1 - 6 of 6 Posts
Status
