1 - 13 of 13 Posts
Hey all, unfortunately for me our newly constructed home is almost ready to move into, and I need the funds out of my 8P A3 big turbo build for new home projects. The car has nearly every suspension upgrade available, the engine is fully built/assembled/sealed and ready to go into the car. The project is currently located in Colorado Springs (I'm in Denver), and I would love to sell the entire thing to someone that wants to take it to the finish line. I've included as many pics as I could find here. I can take add'l photos as requested (might be a delay since the car is in another city).
Prices below are preferred local cash deals - shipping also available, within reason. All prices and package deals are negotiable, I am motivated to sell!
Let me know if you have any questions, thanks for looking!
Engine $5000:
Built CBFA Block:
Block Bored to 83mm
IE 83mm Pistons
IE Rifle Drilled Rods
New Main & Rod Bearings
Built CCTA Head:
3-Angle Valve Job
IE Springs & Retainers
IE Guide Seals
Ferrea Intake & Exhaust Valves (OEM size)
ARP Head Studs
iAbed Rear Main Seal
New Graf Aluminum Water Pump
New OEM HPFP
New Mk7.5R Injectors
Fluidampr
CTS DSG Filter Housing
ECU Currently loaded with Revo K04 + Revo TCU + UM DSG tunes
Engine Fully Assembled/Sealed & Mated to AWD DSG & Ready to go into the car. ($5000 for entire engine as described above, minus the trans)
Full Turbo Setup
BW EFR 7163, T4 TS IWG hotside, Original & SXE Compressor Housings included
IE 450T Turbo Manifold
Turbosmart IWG75 Wastegate Actuator
CTS Intake & Turbo Outlet Silicone Connectors from Boss kit (incl external DV connector)
Turbosmart Kompact EM Plumb Back DV
AWD Custom DP (will also fit FWD)
($2800 for everything above)
APR Intercooler ($750)
Grams 70mm Throttle Body ($old)
APR Catch Can ($old)
Fueling
IE Intake Manifold, machined to accept IE Port Fuel Rail & Spacers (included) + Bosch 550CC injectors (4x) ($1100)
Radium Surge Tank w/ Walbro 450 (high pressure) ($200)
Torqbyte PM4 ($old)
Spare Walbro 450 (high pressure, $75)
TT-RS LPFP ($old)
Aquamist HSF-4 Controller/Pump/Assorted lines & nozzles ($300)
Suspension
KW V3 Coilovers + Ground Control Camber Plates ($1850)
SuperPro Supaloy Lower Control Arms ($400)
SuperPro Rear Trailing Arms/Bushings ($200)
SuperPro Front Sway Bar (AWD) + Superpro Endlinks ($250)
Unibrace UB ($old)
Unibrace XBQ ($old)
BFI Stage 1 Engine & Trans Mounts ($old)
APR DogBone (no hardware, $125)
TyrolSport Front Deadset Kit
Brakes
8V S3 Front Brakes, with BNIB Hawk HP 5.0 Pads & Stoptech SS Lines ($600)
Mk6 Golf R Rears, with BNIB Hawk HP 5.0 Pads & Stoptech SS Lines ($450)
Extras
AWD Milltek Non-Res Catback Exhaust ($500)
Eurodyne Maestro Tuning Suite, never used ($old)
ECS Aluminum Skid Plate ($old)
Innovate ECB-1 Gauge mounted in ECS Steering Column Pod ($300 includes all sensors)
Innovate MTX-D Oil Pressure/Temp Gauge, never installed ($125)
Neuspeed RSe05 17x8 et45 Gunmetal Wheels (4x) with Michelin X-Ice mounted and spare Michelin PS4s w good treadlife remaining ($1200)
Engine $5000:
Built CBFA Block:
Block Bored to 83mm
IE 83mm Pistons
Built CCTA Head:
3-Angle Valve Job
IE Guide Seals
ARP Head Studs
New OEM HPFP
Fluidampr
Full Turbo Setup
APR Catch Can ($240)
Fueling
Torqbyte PM4 ($420)
TT-RS LPFP ($old)
Suspension
SuperPro Rear Trailing Arms/Bushings ($250)
SuperPro F&R Sway Bars (AWD) + Superpro Endlinks F&R ($250 each)
Unibrace UB ($old)
Unibrace XBQ ($old)
Brakes
Extras
BFI mounts???
1 - 13 of 13 Posts
