1 - 20 of 486 Posts
Im literally out of breath from excitement! After much research and alot of luck, I finally have found a way to activate the full mfd on your mk6. Some credit goes to fellow orlando native NADERJ123 who brought up the issue and a dude in cali named vendy for the vag help
Disclaimer: Like always, Perform any modifications at your own risk. I assume no responsibility for failed attempts, damage, or any harm that can come from this. If you don't know what your doing, seek professional help. This is consider informational purposes only. :thumbup:
NEW UPDATE: Verebs1 has discovered that this will partially work in all jettas with out retrofit. When your gas light chimes on, the "Miles left" will show on the mfd. All you need to is turn on the feature in vcds as mentioned below.
Pre requisites:
Vag Com tool
right hand controls retrofitted
(those of you who did the GLI wheel upgrade like me finally get to use those controls:D)
This should work on every MK6 jetta assuming you install the controls and activate via vagcom (not 100% on the S but confident it will work with more retrofitting:thumbup:)
this activates:
  • Miles to empty
  • avg MPG
  • Timer
  • and every other option the tdi has.
Untitled by jettsy, on Flickr
adding right side controls:
If you remove your airbag on your se with conv. and up you should see this box (search the web for how to remove airbag safely):
module by jettsy, on Flickr
to add the right side, simply connect the controls to the open harness slot on the right. Then remove old blank right side cap and screw on new one. follow with vagcom activation. This box in the center of the wheel is the reason the upgrade is easy for some and a little more complex for others. SE with conv. and up has this black box. Other models would need a new wheel.
You will need a multifunction harness if you are just buying a wheel and using your old air bag. This picture illustrates what the standard and Multifunction one have. You will connect the "C" area ti the "1" on the module picture
harness by jettsy, on Flickr
Part number for the harness:
if you have this exact wheel:
all you should need is this:
cimg2142 by jettsy, on Flickr
some quick pics for proof:
CODING:
1.) select 17- instruments
Capture1 by jettsy, on Flickr
2.) Select "Coding"
Capture2 by jettsy, on Flickr
3.) Select Long Coding Helper
Capture3 by jettsy, on Flickr
4.) Select the second box or (Byte 1 as the first box is byte 0)
Check bit 3 "Multi-function Display Active"
Capture4 by jettsy, on Flickr
5) close out and hit "do it!"
Using your controls use the up and down and ok to switch between mfd 1 and 2
I will update this thread as i find out more. Like always, if you have any questions let me know! AND ENJOY!!!!
Discussion Starter · #8 ·
I have left controls. SE convenience with 2.5L and 4Discs Brakes with Bluetooth no GPS
But i do not have right controls.
I was wondering if I have to have Right controls to gain access to tho mod ?
Yes in your case you just need a right hand portion and adapt it to your existing wheel.
Then vag and your good
hmm weird...I've been able to use the controls on the right side of my GLI MFSW ever since I had it put into my Canuck Sportline (SEL w/sport). The only buttons that don't do anything are the left and right buttons (right side). Maybe the guy at the dealership did it for me lol
Nice job nonetheless :thumbup:
I had thought this was possible ever since I saw the manual page about the MFD that said to use the tight hand controls or the right stalk controls (euro style wiper stalk w/rocker +button). Thank you Jettsy! and everyone involved! (now the only question is... will this work on my S... :confused:
I've always thought the clusters would be the same and thought about doing the right button switch.
I have '12 se conv+ sunroof. If I get the right buttons and do the vag work, it should work with full functionality of the buttons or does something else need to be changed? How much we talking about for price on the buttons?
Discussion Starter · #12 ·
Canada already has this feature u.s. doesnt
Discussion Starter · #13 ·
All your car will need is right side controls plus vag com. Button should cost about 70 bucks on eBay i believe
Discussion Starter · #14 ·
Really the main thing is that the activation in vagcom is hidden in instruments and when selected it activates the mfd info along with the controls simultaneously. I still can't believe this has been hiding there for over a year! I finally know how
Much fuel is really left in my car!
Discussion Starter · #15 ·
I have every reason to believe it will. of course, once a new wheel is installed though because just changing the right side control is not enough. The inside of your wheel lacks the ability to support it. But a swap should be easy assuming you have vag com and steering wheel triple bolt square.
Also everyone: I'll keep the first post updated as more info comes. My inbox is kind of blowing up at the moment with questions so I'm doing my best to answer all of them.
Jettsy
Not sure it matters but this appears to be another case of same part, two P/Ns, two production use dates.
For the right hand side there is:
5C0959538A YQV - Titanium Black/White/Chrome Matte Silk - (4/10-9/11) - $195.00 (list)
5C0959538B YQV - Titanium Black/White/Chrome Matte Silk - (10/11) - $187.00 (list)
I don't think the version you get matters but just wanted to let you all know.
Discussion Starter · #17 ·
next thing you would want to check is part numbers of clusters.
Discussion Starter · #19 ·
I know what my cluster P/N is since I removed it last week but there are like 30 clusters I'd have to check which are us ones lol.
yes, my only is doubt is that because of different engines that the cluster may be different. best thing to do is bit the bullet and upgrade your wheel. worse comes to worse right won't work and you can sell to someone who wants it to do this upgrade. I have a gut feeling its going to work though but don't quote me.
5C6920950D (>>03.07.11) Otto engine (160MPH) WTF is that?
5C6920951 (04.07.11>>) CBPA (160MPH)
5C6920951B (04.07.11>>) CBUA, CBTA (160MPH)
5C6920950E (>>03.07.11) Diesel (160MPH)
5C6920951A (04.07.11>>) Diesel (160MPH)
5C6920970 BX () CCTA, CBFA (180MPH)
1 - 20 of 486 Posts
