Hum/Buzz from Instrument Panel
I'm having an ongoing 'disagreement' with VW regarding what I consider excessive noise coming from the instrument panel. I've mentioned it before in another thread, but I want to bring it up again as I want to pursue having it repaired.
The noise can be described as a hum or buzz that originates in the IP. It is so loud at times that I can hear it even at 40 or 50 MPH if the stereo is not on loudly. It is present when I turn the radio and A/C systems off. It sounds similar to a transformer hum, like that on a fluorescent light. It makes the sound even if the engine is not running. If I sit in the car and turn it off and take out the key, I continue to hear the sound until the small screen between the speedo and tach goes dark. The sound stops and the screen goes dark at precisely the same time.
VW central says, as reported by my very sympathetic service writer, that "they (Phaetons and Touaregs) all do it.". Well, today I sat with him in a Touareg (no Phaeton around) and no, it didn't do it.
Does anyone else get this noise? I would like to have others experience regarding this so I can report my findings when I escalate my request to a higher authority.
BTW, the noise is not from the seat fans (turned off) or from the drives in the glove compartment. It is definitely from the IP
I would appreciate your response so I have lots of data to pass on to VW.
If I can just get this fixed, I would consider my car to be just about perfect!.
