Re: i can't get my rotors off!! please help! (tunedjetta)
Those screws for whatever reason are made out of soft metal. It is really easy to strip the philips grooves in the top of them. What I would have done is put a screwdriver in and use a hammer to tap the end. That should kinda dig the screwdriver down into the soft metal screw and give you a little extra bite. It's kinda late for that now. You are gonna need a drill out/extractor kit or you can try what was mentioned before, drill off the head, pop off the rotor and remove what's left, or screw in from back of rotor. For next time, they make screwdrivers with a extra long shank that act almost like a torque wrench. Good for breaking loose hard to turn screws. I got mine from Snap On.
