1 - 4 of 4 Posts
i just got off the phone with them awhile ago.. there called howe racing rads.. the rad i need was quoted at about 300.. with the tepm senser built in.. but no brackets since i will be do a custom mount and welding my own.. but if you guys want one done give them a call.. the core width is 2 1/4 inchs compared to stock 1 1/4 or smaller if i remember.. which means you can get a slightly shorter radiator made and still get proper cooling..
there number is 866-alumrad
Re: i found a compnay to make custom rads.. (onequickg60)
depending on how much room you need you could source a used VR6 corrado radiator as they are an inch or so shorter than the g60 one and should still provide adequate cooling...just an idea
brien
Re: i found a compnay to make custom rads.. (radoboy)
i need it to be pretty short compaired to stock.. i want to mount my front mount IC in front or it and have my plumping go straight through it..
1 - 4 of 4 Posts
