1 - 5 of 5 Posts
how can i stop the surging?
i tried the search, it only shows surging problems for the G60.
i checked all the vac lines, i didnt come across any bad ones.
Its not surging as high as it was, it reaches 2000 though, it wont go away after driving. I know alot of you guys had this problem.
thanks!
Re: i need help, take a look you might be able to help me.... (RedVR6Rado)
There are so many things that I can think of that will cause that type of thing. Usually a vacuum leak will surely cause a surge. Do you have a check engine light to check for codes ? When mine would surge the light would always pop on and after you look up the code it was an easy fix. Has there been any work done to the car lately ? Any lones been disconnected ? Any mods ?
Re: i need help, take a look you might be able to help me.... (BadAssCorrado)
it all started when it over heated, i had to drive home like that. it was a good 2 miles. ever since then the car been surging real bad.
i just changed the water pump and belt thats it.
thats all that has been done to the car, no mods.
come on people i need some help here this is what the forums are for.
im starting to see that you have to known around here to get some help..
[Modified by RedVR6Rado, 11:51 PM 2-11-2002]
1 - 5 of 5 Posts
