1 - 16 of 16 Posts
Discussion Starter #1
i want to make a upgrade but I dont knok which turbo buy: gt2860rs or gt2871r
Help me to choose the best both turbo and specification. Give me why is the best opction.
I will run in both autox and 1/4milla.
gt2860rs
turbo 739548-1 chra 446179-66 compressor
Wh Dia
Trim A/R
Ind Exd
47.2mm 60.0mm 62 0.60
turbine
Wh Dia Trim A/R Type
53.8mm 76 0.86 Wastegated
Exhaust Housing A/R 86ar t25 internal wg
64ar t25 internal wg
48ar t31 4 bolt only external wg
63ar t31 4 bolt only external wg
82ar t31 4 bolt only external wg
the Compressor Housing: standar compressor housing
gt28r style compressor housing
Which injector i need buy bosch or genesis 440cc or 550cc
gt2871r
Turbo CHRA
743347-2 446179-32
compressor
Wh Dia Trim A/R
Ind Exd
53.1mm 71.0mm 56 0.60
turbine
compressor housing up grade: standar compressor housing
large t04E whit 4 inch inlet no watesgate actuador
large t04E whit 2.75 inch inlet no watesgate actuador
large t04s whit 4 inlet and 2.50 aoutlet no watesgate actuador
anti surge t04E whit 4 inch inlet no watesgate acutador
The Compressor wheel trim standar trim 52
48 trim
Modified by jettamk__4 at 4:45 PM 4-15-2010
Modified by jettamk__4 at 4:46 PM 4-15-2010
Re: I need help to make an upgrade (jettamk__4)
what you'd want for auto-x is vastly different to what you'd want for 1/4 mile. if you want to do well in one, you will have to compromise for the other.
pick which you would be your preference.
injectors should be matched to your software. pick the software, and then buy the software that is paired with it.
Re: (jettamk__4)
I would go with the gt2860rs, to use the full potential of the gt2871r you would want to upgrade your rods plus I don't think Genesis injectors come large enough if your looking to use twin spray injectors, I'm not sure, I found bosch ev14 twin spray in 650cc at injector clinic but that's boarder line to cover 450+hp and there's probably no software for them, so standalone would be needed, if you have the time and money get the gt2871r, if you don't! get the gt2860rs better for autox, wont be the fastest at the drag races but fast enough to still brake stuff
Discussion Starter #6
Re: (Autoboost-tech)
May be I would buy gt2860rs but I don´t know which Exhaust Housing A/R I need
1.Which watesgate works better internal or external
2. these Bosch 52lb 550cc High Impedance EV14 Fuel Injector is that you recommending me
Re: (jettamk__4)
Quote, originally posted by jettamk__4 »
I would go with the .63 t31, external wasegate is better
injector clinic has a bored out ev14 550cc that is 650cc
here's a link for the injectors
http://www.nolimitmotorsport.com/prod/IS165-0650H
Discussion Starter #8
Why would you go for .63 t31?
If I choose external watesgate I have to use turbo boost controller
Re: (jettamk__4)
it would work for both your racing, autox and drag, good top end and still spool fairly well, tried to hit the middle from your description of use, external wastegate's wouldn't need a boost controller unless the spring rate was wrong for the boost you want, you can change springs! can't in most internal controllers! externals are more accurate in my opinion, the advantage to internal is ease of install and for tight install situations.
cheers!
Discussion Starter #10
I have two doubts it is necessary to change the maf for 3" and the intelpipe that to be 3 or 2.5 inches
With the injectors if I put them of 550cc works well or needs 650cc
I need to chance the manifold where can I buy. In ebay could be good
Can you give me some links.
I drive daily
Modified by jettamk__4 at 12:26 PM 4-19-2010
Discussion Starter #12
Thank you friend
Which external watesgate I need to buy if i chose 63ar t31 4 bolt only external wg.
The manifold that you show me dose not have hole for external watesgate.
I need also the fuel pump and fuel regulator of precion.
Re: (jettamk__4)
the kinetic one has external wastegate setup, a 38mm wastegate will work great, I like TiAL products my self, a Bosch 044 inline fuel pump will work, I use a Aeromotive regulator, you will just need what is recommended for your upgrade software, 3bar is used most, c2 software seems to work great for a lot of people here
Discussion Starter #14
Thanks.
http://www.rpturbos.com/produc....html
gt2860rs
63 a/r t31 4 bolt external wag
gt28r style commpresor housing
550cc injectors
Bosch Motorsports 044 Fuel Pump
fuel regulator
Manifold
http://www.kineticmotorsport.c...RT_VW
_AUDI_1_8T_T3_TURBO_MANIFOLD-922-0.html
This manifold is too expensive.
If i chose the turbo whit the internal watesgate I save $495 or
this http://www.cxracing.com/mm5/me...-CAST
but I cant use external wastesgate and How i control the boost.
Watesgate
http://www.cxracing.com/mm5/me...=WSGT
Discussion Starter #16
In my city only there are 3 dealers of software who are giac, apr, revo which of these work better.
When i bougth my car I don´t know that was in stage2 may be in 1, My question is
If I buy stage 3 What happen whit the stage in ecu .
Is delete for ever for my ecu
I don´t know what softwarte is.
Let's suppose that in the future I want again stage 2 ´cause sell the car and I extract the repogramacion of stage 3 it stays again stage 2 or software stock the ecu.
Waht do you think about these fuel pump and fuel presure regulator
because I´m worried to spend a lot of money of gas because I drive my car daily.
http://www.ecstuning.com/Volks...23127/
http://www.ecstuning.com/Volks...S5704/
P.s. 1. I´m seeing that the watesgate have two holes one is on the manifold an de other one ??????
2. What is the diffente Between 6psi, 8psi, 12psi, 16psi for the watesgate.
Modified by jettamk__4 at 6:56 AM 4-24-2010
1 - 16 of 16 Posts
