1 - 2 of 2 Posts
Banned
Discussion Starter #1
ok I’m getting Porsche carrera 4s wheels and the rims are( 18 x 10 ET65 rears)
(18 x 8 ET50 fronts) and the rear rims have 285 30 18. And I’m going to have a 20mm or maybe even 30mm adapter in the rear.. I’ll try and get 20mm all the way around if I really need to. My question is, am I going to rub that bad? Where is the tire actually going to end? Past my fender? Or just close enough o pull it off
Thanks for the help guys http://****************.com/smile/emthup.gif
Re: i need help with wheels, tires, offset (1.8Tspeed!)
Im not an expert but, You deffinently dont need a 285 in the rear. I would suggest a 245/35 atleast, but I would probably end up going with a 225/40. with a 30mm adapter it should bring the offset down to 35et in the rear which is what the stock offset is. if you a do 20mm in the front it should bring it down to 30et which I believe will sit about flush with an 8" wheel.
1 - 2 of 2 Posts
