1 - 3 of 3 Posts
Hoping some audio guru's can help me out. I blew a fuse that powers the headunit and I haven't had music in the car for a while now cause I can't find the issue. But what I do know is the spot in the fuse box that holds the fuse for the headunit must have burnt out pretty badly cause it won't hold the fuse in place anymore.
I got to the back of the fuse box but there are way too many wires in the way to trace the spot where the fuse goes. But my question is how do I go about fixing it? Is getting a whole new fuse box assembly an option? Is there any way to repair the spot that holds the fuse in place? I'm stumped.
Thanks for the help/input in advance. :thumbup::wave:
got a multimeter? Before you do anything else you better check and see if either side of that fuse holder has a direct path to ground. No sense replacing anything before fixing the root problem.
1 - 3 of 3 Posts
